What I have here is the J set for lowrider. I do not recall when I printed these but I know for the V2 I never used the parts. I did start with the V1 and those plates are in the back of the photos. Not sure anyone would want those but I am trying to clean up the misc stuff I am just not using.
I am in SW Minnesota so anyone in the surrounding area is welcome to them. I will ship them too but you’ll need to cover the cost of shipping. Otherwise they are free to whom every wants them.
I don’t want to just throw them so hopefully someone here could find a use for them some how.
If you need the flat parts I can cut them out. I do believe there are two 611 plates one is plexi from the V1 and one out of 1/4 ABS plastic. I do not have the Y plates but could certainly cut them and ship them along with this. Again if you are local or near by it would make it easier and I do have the stainless pipe but that is not something I will ship, I could if you want to pay for it but might be really expensive.
The closer I look this is a mix of V1 and V2 Lowrider. I will separate the two and I am not sure who would want the V1. I will cut the side plates and throw them as well. Also from the vast array of misc stuff I should be able to provide all of the bearings too. I also have the two lead screws but not the nuts.
I got the flat parts cut and then sorted the V1 and V2 parts. I am thinking I may be able to get it into a USPS large flat rate box but I have to go to the USPS to get some (that will be 26ish I think). If they do not fit then the shipping is going to be about $40 via UPS. Post office is about $60 and I certainly do not understand that. May have to go with two flat rates… we will see… Let me know.
