at the Moment i have a MPCNC and use it with ESTCAM (CNCshield).
Works perfect for me.
Now, the size of the MPCNC is too small. So, i need a Lowrider2 now
(work surface 1250mm x 2500mm)
Important Question: I see the Board in the BOM is a Mini Rambo. Possible to
controll this Board with ESTCAM (like the MPCNC)?
If not: Other solutions? Or can i use also a CNCshield (Arduino Uno) instead a Mini Rambo?
ESTCAM should definitely be used…
Yeah. The drivers are constant current. So they will send the same amount of current through one coil as two. So if you’re driving two motors off of one driver, series is easier on the driver and you get better results. The trade off is that at high speeds, steppers lose torque. Wiring in series makes that ceiling lower, but we mostly mill at low speeds anyway.
thx, but marlin is not an option for me.
i ve the CNC Shield here, but i switch now to the Open-CNC-Shield.
Think that this Board is the best option for me.
-> direct control via estlcam
-> auto square
-> remote control (wired or wireless)
If u want to use estlcam just buy you a uno with cnc shield v3 and drv8825 and u can us the same setting I’m using for my LR or u can get an mega and ramps 1.4 but not as usefull, I have played with both and can post a pic tomorrow when I’m at my computer with settings
Thx, Shield has no Autosquare and i muss seine Others Features. I get the Open CNC Shield today, think this ist the best Board in the Moment. Now i search dir a Gott place for this Board and the Power supply
Using a dial indicator on mm movement that’s what setting had to be use to get correct movement of leadscrew . Using 8mm leadscrew from amazon. Ran into a very similar problem with the indymill build I did using a mega board and estlcam .
