Anybody else experienced random shutdowns during G38.2 Z0 probing? I get a M112 shutdown reported on the LCD.
My current thinking is that the Z Probe is getting some interference which is confusing things. Possible fixes could be pull up resistor / capacitor?
Thinking that enabling one of these could help (although not sure the difference between these two is connected to Signal/Ground of “ZMin endstop terminals” so suspect that the first is the correct one to try.
#define ENDSTOPPULLUP_ZMIN
#define ENDSTOPPULLUP_ZMIN_PROBE
I made this mod and have run a few successful probes, hopefully this is an enduring fix. Marked as solution but will report back if turns out otherwise.
Anybody know what the second pull up option is for?? (#define ENDSTOPPULLUP_ZMIN_PROBE)
Problem has returned. Anybody else encountered this?
I have attached a 3mm aluminium plate as a probing plate. Maybe the capacitance in this lump of metal is enough to swing things in wrong direction.
Any suggestions.
Am I even barking up the right tree with this M112 shutdown error?
