Hi I’m hoping someone on this forum might be able to help me out.
I’m currently in process of updating from a older Marlin build to the latest v1 510 version. I am also switching PWM control from the Fan port to the new dedicated M03 command pin. Since I will still use the Fan ports for Primary power for the laser I wanted to add a command in the laser menu to enable and disable power to the fan ports (M105 s255 and M107). I cannot find the Laser menu in the Configuration_adv.h file.
Am I missing something or is there somewhere else I need to look
