It’s amazing. These works are perfect and those who are made these works as perfectionists. I really impressive to see those works.
First time I’m using this dovetail bit, and it is unbelievable!
Because my gluing skills are not good, the surface is pretty uneven to start, and the bit sails through endgrain without difficulty even when it gets a bit deep, meaning about 4mm. And the remaining surface is smooth and beautiful.
Thank you!
I am becoming even more convinced that it is slicing the fibers at the bottom and then it is easy to peel off the material above.
