So I have yet to really come close to even dialing my feedrate.
for example, I am cutting an outline of a Denver Bronco logo out of 1/2 plywood… I am at almost two hours on the cut.
I have it set at 400mm/m with a depth per pass .50 on a 1/4 endmill… I am not sure really how much I should be cutting each pass and again I am using a 500w spindle vs the DW660 due to the extreme noise the DW660 puts out.
the max rpm on the spindle is 12k so I am not sure how far to push the feedrate and the depth per pass…
Thoughts?
