Hello,
I have a 3D printer already that was big enough to build the parts for the MPCNC
After building my MPCNC I bought a 200x300mm heated bed to make it a large 3d printer.
I like the idea of a bigger “dedicated” 3d printer as I want the MPCNC to be “dedicated” for engraving/lasering.
Now, I am about to start printing the MP3DP- Milled/Printed 3D Printer as this looks like a great option as a second larger printer.
I see that the MP3DP was designed for a 200x200mm bed.
I would like to use my 200x300mm bed instead of a 200x200mm bed.
With that being said, my questions are:
-Would it be better to lenghten the platform or extruder carriage linear rods to meet the new size?
-If I used the bigger bed, would I just make that axis 100mm longer(rods, wood frame and belt)?
-I also thinking of making it dual extruder, if I did, would I then add the width of the extruder/stepper to the 100mm I already added in last step?
Any info/suggestions would be helpful to make the frame proper size to fit this heated bed.
I hope this is in the right category, if it isn’t then I apologize.
Thanks,
Cliff
