what are your favorite 3d printable cases for the mini rambo and LCD that you guy’s are using?
Here is a case that I have been working on for the Folgertech Delta. I have to replace the electronics on that machine & was originally going to use the arduino, but now I am probably going to use the Rambo mini. I was just looking at changing that to use the mini Rambo yesterday. To use it with the MPCNC, you would just need something screw the back to or it would be simple enough for me to make another optional back plate for it. I was going to upload it after I finished printing all the parts, but if you are interested in this design, I could upload it in the next couple of days after tweaking a little more. I remixed this from a design where I just had the LCD. You did not say which LCD you were using. This uses the 2004 LCD display.
Here is the design with just the LCD display
I have been looking around for a case for the rambo mini as well. I was planning on trying to draw something up once I decided on the table and how I am going to mount it. Figured maybe I would incorporate a couple of fan mounts into it to keep things cool. Its hot down here in Texas out in the shop. If I come up with something that works I will be sure to share as well.
Geodave I would be interested in the design for the MPCNC for sure!
I’m using the LCD that is available in the online store here:
That case looks fun and most of it can easily be cnc’d out…
I will see if I can make a version for the graphic display. I would probably have to make it a little taller for that display.
geodave that would be awesome! I’ll def give it a shot if you post it up for us!
This is what I came up with so far. I shortened the length of the assembly by 20mm since the graphics display is so much shorter than the other display, but will probably make another version the same length as my original design because it looks like the USB cable might be difficult to get in there unless you take the end cap off or cut a hole in the end cap. I had to raise the height of it about 3/4" for the taller graphic controller.
Nice work Dave! I may be interested in giving this a try. I don’t see any access holes though for the USB and SD card. Maybe I am just overlooking it or something.
Oops, I did miss the SD card access. I saw that problem initially, but forgot about it when working with the other design problems. The USB cable I was going to bring in from the back until I made this design shorter. I did mention the need to put a hole in the end cap for the USB.
After Johnny’s comments on this, I went back to the drawing board & think I have worked out the problems with the USB & the SD card. I took Ryan’s Full Graphic Smart Controller case & overlaid it on my design to get the SD card cutout. I decided to keep the length of this the longer length I had before. That way I should be able to design to use either the 2004 LCD controller or the Graphic controller. For the rest of the wiring, I am planning on those coming in the back. Since I will be using this on a Delta printer, all of those wires go into the printer & I will probably have the usb cable going that route also. For use with this MPCNC, seems like the simplest solution would be to make a wooden back with the holes to suit the individual. I will make a DXF profile of the outline & mounting holes to make that a little easier. I wanted to center this display in the faceplate, but having it to one side of the faceplate simplifies the design. The brackets will have captive nuts to use with the end caps. With the end caps assembled last, should be able to install all the parts. I attached updated images.
Well done! I like it!
Looks good… I’d def try 3d printing it all to see how it works out.
Think I have all the problems I have seen worked out. I need to clean up the openscad code a little & will see if I can post it to thingiverse today or tomorrow. I do not know when I will have a chance to print these parts, but sounds like others are interesting in beta testing this design. This will work with Rambo Mini or the Arduino Mega.
It could also work with the Rambo if I add a little more depth to the brackets. The Rambo board is about 32mm wider than the Mini. That would change the brackets, end covers & top plate. The face plate & back would be the same. I have the Rambo on my Makerfarm i3v, but probably will use the Rambo Mini on my delta printer.
Since there was some empty space on the one side of face plate, I added an option to add 3 lines of text to that area. The image shows an example text you might put there. I was going to try adding Ryan’s logo on there, but since this is printed on the bottom, looked like it would have too much overhang in the cutout. This spot might also be a good place to put that big Emergency stop button.
I added a back plate to the design now with a couple of holes for the wires & dove tail joints to hold in place. The holes for that I sized to use the electrical endcaps in this thingiverse design: https://www.thingiverse.com/thing:978384
I could also add dovetail joints to the endcaps, but when I tested that idea a week or so ago, it was kind of difficult to get them off.
I have tested what I can of matching parts, but can not check the graphics display connection since I do not have that part yet. If someone can test print the faceplate, I have attached a zip file that has the openscad file of just the face plate portion along with the STL file for a .6mm height test print of the face plate & the full height version of the faceplate. If it does not quite fit & you are familiar with openscad, you should be able to adjust a variable or two in the openscad file & reprint the test, or if you can tell me how much any of the holes are off, I can generate another stl file.
FacePlate_Rev66.zip (64.6 KB)
I will try to take a look at it this evening when I get home and run the test file to check for fit with the LCD. I am not familiar at all with that cad program so will let you know how it turns out and if anything needs to be adjusted.
Test file was a success. All the holes appear to line up. I will print the whole front plate next to check for fit and let you know.
really interested in this.
Cool, thanks for testing that. I have changed the front plate a little since that version, but only made it a curved edge at the top instead of the 45 angle cut. I also added the option for dove tail joints on the end caps. I think those dove tails will work on those now that I put a 3 small screw driver access slots on the brackets to make it easier to take the end caps off. Seemed like it was going to be difficult to put those end caps with screws and keep the locknuts in place unless they were set into the plastic with a soldering iron. I am going to test print a bracket & end cap today.
I pull the full faceplate off the printer this morning. Everything seems to line up and fit fine. However, I think it will need a stand off for the screws that mount the LCD on the right side of the screen. Since this doesnt stretch to the other end like your longer LCD there is a gap between the faceplate and the board on the LCD that wont be filled by the brackets on the ends. Other than that with the little speaker pressed against the faceplate the fit of the LCD face looks good.
