Can anyone drop a link for the right Configuration file for a MiniRambo 1.3. I’m running the LCD screen and no dual endstops. I can’t figure out which one to use.
Thanks
- Go to the.GitHub page, https://github.com/Allted/Marlin
- Use the branch pull down menu to select MPCNC_MRambo_T8_16T_LCD
- Hit the clone or download button and download the zip
- Extract the zip file and you should be good to go
Thanks Bill. I downloaded and extracted it. When I try to compile it fails. I’m using Arduino IDE 1.8.12.
Here is the error message if its relevant:
Arduino: 1.8.12 (Windows Store 1.8.33.0) (Windows 10), Board: “RAMBo”
sketch\src\HAL\HAL_AVR\u8g_com_HAL_AVR_sw_spi.cpp: In function ‘void u8g_spiSend_sw_AVR_mode_0(uint8_t)’:
sketch\src\HAL\HAL_AVR\u8g_com_HAL_AVR_sw_spi.cpp:90:3: error: ‘U8G_ATOMIC_START’ was not declared in this scope
U8G_ATOMIC_START();
sketch\src\HAL\HAL_AVR\u8g_com_HAL_AVR_sw_spi.cpp:90:3: note: suggested alternative: ‘SIG_ATOMIC_MAX’
U8G_ATOMIC_START();
SIG_ATOMIC_MAX
sketch\src\HAL\HAL_AVR\u8g_com_HAL_AVR_sw_spi.cpp:100:3: error: ‘U8G_ATOMIC_END’ was not declared in this scope
U8G_ATOMIC_END();
sketch\src\HAL\HAL_AVR\u8g_com_HAL_AVR_sw_spi.cpp:100:3: note: suggested alternative: ‘U8G_ESC_END’
U8G_ATOMIC_END();
U8G_ESC_END
sketch\src\HAL\HAL_AVR\u8g_com_HAL_AVR_sw_spi.cpp: In function ‘void u8g_spiSend_sw_AVR_mode_3(uint8_t)’:
sketch\src\HAL\HAL_AVR\u8g_com_HAL_AVR_sw_spi.cpp:110:3: error: ‘U8G_ATOMIC_START’ was not declared in this scope
U8G_ATOMIC_START();
sketch\src\HAL\HAL_AVR\u8g_com_HAL_AVR_sw_spi.cpp:110:3: note: suggested alternative: ‘SIG_ATOMIC_MAX’
U8G_ATOMIC_START();
SIG_ATOMIC_MAX
sketch\src\HAL\HAL_AVR\u8g_com_HAL_AVR_sw_spi.cpp:120:3: error: ‘U8G_ATOMIC_END’ was not declared in this scope
U8G_ATOMIC_END();
sketch\src\HAL\HAL_AVR\u8g_com_HAL_AVR_sw_spi.cpp:120:3: note: suggested alternative: ‘U8G_ESC_END’
U8G_ATOMIC_END();
U8G_ESC_END
exit status 1
Error compiling for board RAMBo.
This report would have more information with
“Show verbose output during compilation”
option enabled in File -> Preferences.
Follow the instructions here:
https://docs.v1engineering.com/electronics/marlin-firmware/
You don’t have u8glib installed correctly.
The firmware should actually be: https://github.com/Allted/Marlin/tree/V1CNC_MiniRambo
The one @billsey pointed you to is older.
Thanks for the help Jeff.
Arduino IDE is giving me this issue now.
avr-gcc: error: CreateProcess: No such file or directory
Multiple libraries were found for “U8glib.h”
Used: C:\Users\KaleD\Documents\Arduino\libraries\U8glib
Not used: C:\Users\KaleD\Documents\ArduinoData\packages\rambo\hardware\avr\1.0.0\libraries\U8glib
exit status 1
I don’t know windows very well, but is that the version from the app store? I don’t think that works (but I don’t know why).
I reinstalled Arduino IDE and it seems to be working correctly. I must have had the app store version before. thanks for the help
That was it, the store version doesn’t work.
