MKS GEN L DUAL endstops Z problem
Hi Everyone,
Sorry by advance my english is no good, i from Belgium natural language is french.
I have follow this topic before post: mks-gen-l-dual-endstops/11210
Marlin firmware: MPCNC_Ramps_T8_16T_LCD_32step_DualEndstop
All motor work correctly, but, only endstop Z right not work, i have tested M119 see result, i have signal
x_min: open
y_min: open
y2_min: open
z_min: open
z2_min: open
z_max: TRIGGERED  <--- this is my endstop right Z
>>> M119
SENDING:M119
Reporting endstop status
x_min: open
y_min: open
y2_min: open
z_min: open
z2_min: open
z_max: open
My file configuration_adv and config is modified based on Teaching Tech
#define USE_XMIN_PLUG
#define USE_YMIN_PLUG
#define USE_ZMIN_PLUG
#define USE_XMAX_PLUG
#define USE_YMAX_PLUG
#define USE_ZMAX_PLUG
// Enable pullup for all endstops to prevent a floating state
#define ENDSTOPPULLUPS
#if DISABLED(ENDSTOPPULLUPS)
// Disable ENDSTOPPULLUPS to set pullups individually
#define ENDSTOPPULLUP_XMAX
#define ENDSTOPPULLUP_YMAX
#define ENDSTOPPULLUP_ZMAX
#define ENDSTOPPULLUP_XMIN
#define ENDSTOPPULLUP_YMIN
#define ENDSTOPPULLUP_ZMIN
//#define ENDSTOPPULLUP_ZMIN_PROBE
#endif
// Enable pulldown for all endstops to prevent a floating state
//#define ENDSTOPPULLDOWNS
#if DISABLED(ENDSTOPPULLDOWNS)
// Disable ENDSTOPPULLDOWNS to set pulldowns individually
//#define ENDSTOPPULLDOWN_XMAX
//#define ENDSTOPPULLDOWN_YMAX
//#define ENDSTOPPULLDOWN_ZMAX
//#define ENDSTOPPULLDOWN_XMIN
//#define ENDSTOPPULLDOWN_YMIN
//#define ENDSTOPPULLDOWN_ZMIN
//#define ENDSTOPPULLDOWN_ZMIN_PROBE
#endif
// Mechanical endstop with COM to ground and NC to Signal uses ā€œfalseā€ here (most common setup).
#define X_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Y_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Z_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define X_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Y_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Z_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Z_MIN_PROBE_ENDSTOP_INVERTING true // Set to true to invert the logic of the probe.
//#define X_DUAL_STEPPER_DRIVERS
#if ENABLED(X_DUAL_STEPPER_DRIVERS)
#define INVERT_X2_VS_X_DIR true // Set ā€˜trueā€™ if X motors should rotate in opposite directions
#define X_DUAL_ENDSTOPS
#if ENABLED(X_DUAL_ENDSTOPS)
#define X2_USE_ENDSTOP XMAX
#define X_DUAL_ENDSTOPS_ADJUSTMENT 0
#endif
#endif
#define Y_DUAL_STEPPER_DRIVERS
#if ENABLED(Y_DUAL_STEPPER_DRIVERS)
#define INVERT_Y2_VS_Y_DIR true // Set ā€˜trueā€™ if Y motors should rotate in opposite directions
#define Y_DUAL_ENDSTOPS
#if ENABLED(Y_DUAL_ENDSTOPS)
#define Y2_USE_ENDSTOP YMAX
#define Y_DUAL_ENDSTOPS_ADJUSTMENT 0
#endif
#endif
#define Z_DUAL_STEPPER_DRIVERS
#if ENABLED(Z_DUAL_STEPPER_DRIVERS)
#define Z_DUAL_ENDSTOPS
#if ENABLED(Z_DUAL_ENDSTOPS)
#define Z2_USE_ENDSTOP XMAX
#define Z_DUAL_ENDSTOPS_ADJUSTMENT 0
#endif
#endif
//#define Z_TRIPLE_STEPPER_DRIVERS
#if ENABLED(Z_TRIPLE_STEPPER_DRIVERS)
//#define Z_TRIPLE_ENDSTOPS
#if ENABLED(Z_TRIPLE_ENDSTOPS)
#define Z3_USE_ENDSTOP YMAX
#define Z_TRIPLE_ENDSTOPS_ADJUSTMENT2 0
#define Z_TRIPLE_ENDSTOPS_ADJUSTMENT3 0
#endif
#endif
I have prepared shema for my board
mks
i not found my error Can you help me please?
Thank you
Make sure the actual endstop is wired correctly.
Hello Barry, thanks for reply yes is correctly connected after test push is : z_max: TRIGGERED and no push is: z_max: open
Are they on the right side? If you home Z and trigger the other one, does that side stop?
I reverse the connection from left to right for the test and it works
after a lot of testing i changed this section to the original one provided in the firmware, I also changed the endstop with a new one
i tested each endstop pronterface:
result:
All endstop not push
Recv: x_min: TRIGGERED
Recv: y_min: TRIGGERED
Recv: y2_min: TRIGGERED
Recv: z_min: open
Recv: z2_min: TRIGGERED
Recv: z_max: TRIGGERED
Push on Z left
Recv: z_min: TRIGGERED
Push on Y left
Recv: y2_min: open
Recv: z_min: open
Push on Y2 right
Recv: y_min: open
Recv: z_min: open
Push on Z2 right (replaced by new)
Recv: z_min: open
Recv: z_max: open
and finally Push on X
Recv: x_min: open
Recv: z_min: open
I think Iā€™m almost there but a detail must escape me, if for someone it seems obvious thank you in advance for providing me a little help :slight_smile:
The good news is, they are changing. I see two problems here:
  1. Most of the endstopā€™s logic is inverted. X_MIN , Y_MIN, Y_MAX, Z_MAX are all backward. There are two ways to fix that. Either change the related X_MIN_ENDSTOP_INVERTING, etc. to ā€œtrueā€ or wire the endstops the other way.
  2. Z2 isnā€™t registering on the zmax pin. In Configuration_adv.h, in you can set Z2_USE_ENDSTOP ZMAX. Or else, connect that endstop to the xmax port.
Both problems have a wiring or software solution. The difference is minimal.
Many thanks Jeff,
I modified the line in configuration_adv
Through
#define Z2_USE_ENDSTOP ZMAX
and in configuration
everything works perfectly
thanks again !
