I will have to look at your design a little closer. Think I would like to use V-Slot instead to hold up better under outdoor conditions, plus I have some extra around. Have you seen the types like this one with a dual rail design that extend about twice as far as the length of pipe used? https://www.instructables.com/id/Arduslide-Arduino-Camera-Slider/ I have seen a commercial one using this dual rail design also. Guess it is not patended.
Huh. That’s clever. I don’t know how I would do that with the bearings and EMT, but it does really compress the size.
I just found a double slider that using the V-slot C-beam & I happen to have an extra 500mm C-beam. I will have to look at this design a little closer. This might also help you to see how you could use the double slider with EMT.
https://openbuilds.com/builds/openbuilds-c-beam-double-slider.3462/
It just occured to me that the ESP32 software could be used to control the toy 3D printer that I have (at least the X, Y parts). I guess I’ll have to get that working too. I’m tempted to even go so far as to set up the TMC interface on a TMC supported board…
OK. It’s working!
Just had time for a quick set up before dark. I have much to learn about photography.
It’s working…
It’s a little wobbly. I actually tried printing bearings, and they aren’t super tight on the tubes, so something is off there. I doubt they wore down enough to be too small.
But generally, it’s working pretty well. Now I have to learn how to take photographs. It’s much harder to do, since I need some consistency between photos, but also, the light and motion settings of the first image probably won’t be right for the final photograph. So I have to relearn all that stuff.
I haven’t made a battery connector, and the IR logic is pausing the motion code momentarily, so I will probably move that to a thread (ESP has two cores, awesome).
Grrr. Forums are eating my post.
It’s working…
I really don’t remember where I first saw camera slider software I thought I might model mine after… but IIRC at least one of them used interrupts and an ISR to handle the IR inputs. I could never get that part to work properly so I just coded it inline in the loop… and it was good enough for what I was doing at the time. I’m sure you would be far more successful getting interrupts going (since you actually know what you are doing )… and it might/should take care of the momentary pauses you’re seeing?
I can see why that’s confusing. I am not using the IR as input to control the slider, I have the web page for that. The IR is to send a message to the camera to take the next snapshot. When it does, the motion pauses for about 1/2 second, and then the motion tries to catch up. With the really slow timelapse above, it isn’t noticeable, but I still know it’s there.
Since my camera doesn’t have a timelapse, what I’ve been doing is sending the IR signal to take a photo every 6 seconds (configurable through the web page) and then I use ffmpeg to stitch them back together into a movie.
I’m hoping I wake up early enough tomorrow to capture the sunrise… Maybe I shouldn’t promise that.
“Violins on TV”… never mind
I made one finally with the sun out.
Beautiful! And, snow already! Fat chance it’ll ever snow down here in San Antonio, Texas…
It’s the third snow we’ve had. We even had a school closure, which we don’t normally get even in deep winter. It’s going to be 55F today though,
We’ve gotten into the high 20’s a couple of nights… which is cold for us. A number of fronts to cool us for a couple of days… and then it’s back up into the 70’s. We’ve really got it rough…
Love the new look of the forum… it’s gonna take me a while to get the hang of it though. Thanks for all your help/contributions to the efforts to get it switched over. I’m sure Ryan appreciates it most of all!
