Hi All
I’ve just finished the mechanical build of the MPCNC and am moving on to the electronic part. The mechanical build is pretty well documented but the electronics part seems a little less coherent.
I ordered the kit for single and dual end stops but I think my rambo v1.4 board shipped with single endstop fw, this is fine, I’m working to update it to dual endstops.
My work area is roughly 600mm x 600mm and when the X & Y axis are @ 600mm & 600mm respectively using the auto home feature causes an error before it gets to home because, I assume the home distances are greater what Ryan recommends to build.
I did try set the offsets to 600mm but it told me that was too large. Before I load the dual endstop FW what do I need to modify to have the FW play nice with the oversize MPCNC?
Many Thanks
Tony
