I’m building a metric MPCNC. Work size will be 500mm x 500mm x 75mm.
I’m using 25mm stainless steel conduits, 2mm thick.
Parts are (being) printed using premium PETG with 0.20mm resolution and Gyroid infill.
Hardware parts bundle is on its way. It reached Paris yesterday and and will soon be held by french customs for rand() * pi * 42 days if everything goes right.
Sliced with Slic3r Prusa Edition with default « 0.15 quality » settings, except for the first layer where I divided speed by 2, and the perimeters set to 6. I use a brim on all prints. For the post processing part I just shave edges of the first layer after removing the brim.
I already replied to your other thread but now that I am seeing this again. I would say tighten the 5" a smidge and maybe loosen the two 1.5". That in theory should move it a hair the right way.
