I am running the mpcnc firmware and using repetier host. I am running into issues with g2 g3 commands showing as errors in the log window in repetier host. Anyone have any idea’s?
Turns out my post processor was missing some code but I have straightened it out now. If anyone uses artcam here is the postp for marlin. Rename to marlin.con and Copy the file into C:\Program Files\Autodesk\ArtCAM 2018\postp\ and you are good to go. For tool changes save toolpaths as separate files.
marlin.con_.txt (2.23 KB)
it does not appear on machine file format on version 2018 when tring to save the tool path ! someting i do wrong i think ?
