I think I am lost or missed something in configuration can you please provide me the links where I can strart from scratch
Iām not sure what you mean by configuration. If you mean firmware, then see the firmware section of this page.
Is there a way to specify the working area on table in firmware or other places.
Yes, but you will need to compile a new version of the firmware. In configuration.h it is these two values:
// The size of the print bed
#define X_BED_SIZE 300
#define Y_BED_SIZE 300
See āCompile your own (source)ā at the bottom of the link I provided.
Hello Robert can you please guide me to set up the lowrider2 by video call through whattsup my mobile number is 0097339449110
Iām sorry I cannot, and Iām probably not the right person. I donāt use whattsup (and donāt want to add it to my life), I donāt have an SKR Pro board nor a TFT screen, I donāt have a LowRider, and I have very limited experience with Microsoft Code and PlatformIO. What I do on this forum is to read material to both build up conceptual knowledge to āguessā solutions, and to post other-people-solved-it-that-way solutions.
I will continue to to watch out for your topic and will continue to contribute. When I have problems like your struggles, I take whatever Iām working on to the simplest place I can get it to work. So if it were me, my first two steps would be:
- Hold the knob down on TFT to put your display in Marlin mode.
- Verify that you have the latest V1 firmware installed.
Assuming those two steps go well, I would put the crown g-code file on an SD card and run it in the air. Copy and paste the g-code from here into a text editor and save it as a .gcode file. If these steps donāt go well, you are fortunate that the SKR Pro can have its firmware updated by simply throwing a file on an SD card and plugging it in (no compile needed).
One other point. Because of the way this forum operates, you will get better/more responses if you open a new topic for each issue you find. Tackle your issues one and a time, and post a new topic at each roadblock.
Thanks alot dear Robert for all support to in this level and really appreciate.
