This is my multimeter, am about to adjust the vref on my 8825 drivers.
Have I set it correctly for reading less than 2volts
Could someone confirm for me please? If it’s wrong could you tell me which setting it should be on
[attachment file=38084]
That should do it.
isn’t 200mV only 0.2 V ? I would think you need the 2000mV setting.
Yep. I concur.
You have the leads in the right place, that’s the most important part. Just try to be extra steady with those leads. If you don’t short something, you’ll do fine.
