What I like: a good designed CNC.
The forum was a big help for me to find the solution for the only problem I had.
Motion no problem.
Autohome always problem.
This should be in the manual: the bedsize in the firmware caused that issue.
How much difference is there? It doesn’t look like much.
Z error is hard to remove. Surfacing the spoil board (and a little extra) is one way to make it better. But a lot of tricks in CAM can make the tolerance acceptable.
For example, if you are cutting out parts, cutting an extra few mm isn’t going to hurt anything (except your spoil board). When cutting pockets that don’t go all the way through, you need to consider which reference face matters and set your Z nearby. If you are cutting mortises, then a little extra deep isn’t a problem and they are small, so you don’t have much error in a small area. If you are carving a design with a v bit, having a sharper bit will make the Z error have a smaller affect on the XY error.
I’m gonna follow that idea. I had started a surface job. I wanted to stop it. I noticed disable the steppers with a Running router is a bad idea. The Z Drops down. Is there a better way to stop a Task?
I noticed another problem. Thé pc was already disconnected from the pc before the reset. Is it better to do a job with sd card?
Maybe you noticed : Cnc is totally new for me.
I’m experienced in 3d printing. Build my 3d printer 10 years ago and still printing with it.
That is hard core. Printers were not easy to use 10 years ago. Not many people who built them then are still using the same one.
You can pause, but there will be a few commands still in the queue, so it may take a minute to pause. Especially if the next few lines are very long moves. Then you can power off the router, and jog it to a safe parking place.
In an emergency, just kill the power. Your work may get ruined. But it probably already is if there is a need to kill it immediately.
