It could be a few things but you didn’t really give any information on anything you are using so I suggest cutting the new plates as soon as possible and starting from there.
It works fine above 5cm from the lowest posible point so i think i just raise the spill board a bit and cut new plates with the cnc. Thanks again with the help
Yup, having the same issue. Am going to cnc the plates out of MDF so I know it’s flat and eliminate that from the equation also. I made a template on my 3d printer but alas my jig saw skills are not the greatest.
Wife calls it a toy so I gotta get it working soon.
Crazy how just a tiny little tweak can make such a huge difference, right? When I first built mine I could not figure out why so many people had an issue…turns out I was instinctively leaving that loose and it took a while to learn others were not doing that.
