I just completed the wiring on my MPCNC with the dual-endstop setup purchased here last week. Homing for X and Z is working as expected but when I attempt to Home Y only Y1 actually moves and Y2 locks which eventually causes Y1 to start skipping.
Using the LCD, I can move Y in both directions smoothly. Any Ideas?
Board: Rambo 1.4
No changes to firmware which is listed as Bugfix 2.0 on the LCD.
I don’t yet have repetior-host setup so can’t send g-code yet but when motors are disconnected and I home y with the LCD I can manually trigger the endstops and it sets to zero. The issue whenmotors are hooked up and I home, the endstops are never hit. The Y-Axis just binds and the Y1 stepper starts jerking. It is odd because as I mentioned in my earlier post, the movement is smooth as silk if I just use the LCD to move. If I were to make a guess I would say something wrong with the code that is sent when I home but I am sure you have tested that well.
I will get repetier installed and try what you suggest.
Absolutely impressed with the design by the way. Can’t wait to make some dust…
I am not sure what could cause that. M119 will really supply a definitive answer. If you can’t find an issue with your wiring reflash with my current firmware.
