Hey everyone, time for an update!
First, thank you, everyone, for the compliments on the ender, and happy to note all parts printed without a problem! No idea how much actual print time or filament was used. I just kept filling the bed when the last one was done until they were all printed.
Some final decisions were made and I have completed the build-up to wiring stage.
Decisions made:
-Final sizing. I decided to go with a 2’x2’ (610x610mm) working area and give up on the idea of aluminum at this point. There is just too much I want to learn ( wood carving, plotting, engraving) and experiment with and aluminum is something I think ill rebuild for and attack after I get some basics down. The final outer dimension of 35"x35" (889x889mm), Z work height of 4" or 101mm.
-Drag knife I went with one exactly like what Ryan has here. but ill probably be trying out a few models and will report back later what one I like most.
-Table design I decided to just build one with the same design I built my GF’s clay throwing table. I took outer dimension and added a couple of inches here and there for drag chains and a small work area, eyeballed the height so I didn’t have to bend over to watch it carve and boom, the table turned out giant… I guess its great extra storage or a future enclosure for some printers lol. (pictures below)
Mainboard and drivers. Now that this project is my new baby that I’m interested in I stripped the half working delta and re-purposed the Big Tree Tech skr 1.3 mainboard and 2208 V3 drivers to this project. Overkill but I had them. Planning on running UART config for this so I can change and monitor driver parameters in software.
I bought some new motors. I have enough projects that I can re-purpose the originally re-purposed motors that I was going to use xD. Now using 5x Nema 17 Bipolar 59Ncm (84oz.in) 2A for this build.
-I decided ill go with dual end stops, at-least wire everything up now, so that it’ll only be a firmware update to swap between them or not.
-Planning on running marlin 2.0 as of right now. i have the most experience with it but open to switching it up if something else offers better features or control over the machine.
The build went relatively easy so far. Documentation is great on here, can’t thank Ryan enough!
I did decide to smooth out my emt with some 220. Barrings I never did end up cleaning from the factory, they were all greased up and I just wanted to build lol, ill probably regret that later but test rolled them all as they went in and they seemed to be working good. I printed mid-span supports and some additional feet thinking I would use them but from what I’ve seen so far as long as I stay away from aluminum I should be good at this size. Correct me if I’m wrong. I have them if I want to add em later.
Questions still needing answers or decisions.
- My motors run Rated Current/phase: 2.0A and my drivers are Phase Current: 1.2A RMS, 2.0A Peak. I’ve been suggested to run them at 1A for safety. Debating what to set these to and or if I should pick up some 2209s to get a bit closer to the 2A limit, maybe 1.5A. Any suggestions here would be great.
Motors - Amazon
Board & Drivers - Amazon
-What microsteps to run my motors at. 2208s go up to 1/256 microsteps but from my understanding the more microsteps you go the better the resolution/smoothness of motor operation but also a decrease in holding torque? Also with UART I though there is some fancy stuff for switching this on the fly depending if the motor needs it based off its torque vs hard coding it. Idk more research is needed here. Also, stealth chop 2 / spread cycle idk if I should have these features on or not.
Need to extend my motor cables, I have some 20g wire I bought for LEDs, I think this will work. Worried about all these interference problems I’m seeing with not enough insulation in the wiring. would this work? should I get shielded? Bigger gauge wire?
Wire - Amazon
Debating on what connectors to buy for right off the motor to the wiring harness. I feel like ill want a plug instead of hardwiring motors straight back to board.
-Debating on the surface for the, threw down some 1/4" ply since I had it around but might swap it for some 3/4 mdf or something to try and get it a more flat surface. Plotting and laser will be the first couple of jobs with this guy before I break out into wood carving. Any recommendations here?
That’s all I got right now, at lunch at the moment. I’ll update later this weekend with more choices and build updates. BTW Kitchen remodel is pretty much done!
IMG_20200220_203346|666x500,50%
