Hi, all. I started assembly of my Lowrider today. As you might be able to see in the photo (circled in yellow), one of the four points where the XZ mains should sit flush on the YZ rollers is slightly high. I’ve read the docs about possible adjustments, but am wondering if more experienced users have a specific recommendation about which adjustment I should try first. If it helps, the Y axis rolls freely. I have the Z leadscrews installed, and the Z axis moves pretty freely by hand, but I haven’t yet wired/powered the motors for that axis. Thanks in advance!
Loosen the X tubes and let is settle, then tighten them back up.
Thanks!
