I think the setting for probe offset in the latest firmware (415?) is not working correctly. In my previous version (last year sometime) I could set it with the following lines in the configuration.h file (syntax may be off as I am not at my computer)
The latest seems to have grouped this into a single line (though I cannot recall exact syntax, the correct line is in the configuration.h file). The new style does not seem to be in the marlin docs yet.
XYZ_PROBE_OFFSETS_FROM_NOZZLE ( 10, 10, 0.92)
Problem is it does not seem to be using the value that is set. Probe works, but indicates 0 instead of the probe thickness. I know I could use a G92 in the start gcode but I have become used to having it set in firmware. Has anyone else experienced this?
Yes. My old value was -0.92 , but since I am in a doctors office waiting I probably typed it wrong in the above post. Pretty sure I have it right in the firmware, but I will double triple check once I get home. It may be I have it wrong and used a positive value. That might result in the zero since I have a zero limit set for z after homing.
The x and y values are the defaults, but ignored as I don’t probe for x or y (yet).
