Looking to build this table as a circle is their a way to build with quiet motors?
I am not if the noise is from the giant steppers I am using or something else. I do know speed changes this pretty drastically. I haven’t had time to take it apart and put smaller steppers on it yet. I usually just upload a design and let it draw then turn it off. It really isn’t that exciting to watch for me but I love the finished design.
Not sure what others think of the noise. I live in a really quiet place so hopefully I am just being overly sensitive.
maybe you should try this? I saw it can reduce noise dramatically
That isn’t it, the same steppers and drivers are silent on all the other machines. It is either the way the motors are mounter (doubt it the MP3DP is similar) or the corexy configuration. It causes some odd sounds for sure.
I wonder what software you would need for this type of plotter
That is also different hardware. I only made a square.
LinuxCNC could work, because there in are different kinetic systems included.
