Henno
(CHRIS HENNESSY)
1
Hi all hopefully I can get some help with my issue, I’ve tried a few searches but nothing similar to my problem.
I have recently build my LowRider2, with ramps 1.4. I have movement when using repetier host and by using the LCD control knob.
I have loaded the crown file and started the file, but nothing moves. I can hear the motor noise changing like it is moving but nothing.
Please help im so close
Sorry I’ve worked it out. Settings were wrong. Not sure how to delete this post
jeffeb3
(Jeffeb3)
2
You can share what was wrong. I’m sure you’re not the only one to run into it.
Henno
(CHRIS HENNESSY)
3
Silly mistake, got excited that i was close to finishing the build. I hadn’t resized the crown file before I exported the gcode
It was trying to do the crown test file but it was super small.
Ive learnt if you follow all the instructions it saves frustration at the end…
jeffeb3
(Jeffeb3)
4
Aha. That makes sense. Thanks for sharing.
There is a premade test crown gcode file you can use too, which is good for checkout.
