I am in USA and I have steel supplier with many options for tubing at 1.050" OD. I can’t seem to find any information on whether this will work or not. 25.4mm should be 1.000". 1.050" converts to 26.67mm. I have seen some posts where the 1.050" size is mentioned but where it may be acceptable. I tried searching this forum but it always says no results found, regardless of what I search for. Thanks for your help!
No, It isn’t even practical to use 25.4mm tubes with 25mm “F” parts (.4mm difference).
ETA: You should be commended for sorting out your tubing size before buying/printing parts. Too many people make this discovery after they have acquired an incompatible combination of parts/tube.
I wish it would work but no, it’s too far out. The “black pipe” for water or gas at the orange store is about 1.05 and if it worked it would be a nice option stiffer than EMT conduit that doesn’t require a specialty store.
Lee,
It’s nice to save money , but long term the stainless steel is the best option! Corrosion is a problem in galvanized and raw steel. Get the 1" OD .065 stainless steel. Save yourself many problems and headache:dizzy_face:. I have the SS. E
I’ve seen posts about the corrosion problems. Good luck on build.
For my first CNC, I wanted to conserve costs and upgrade later (to stainless).
In the docs, it says you can get steel tubing for $12. Where in the USA can you get that? Can’t find anything at Lowes or Home Depot. It’s all 25.4mm Inner diameter.
You have to go to a steel supply house where contractors/metal work would shop. You could also check grainger supply. Like I said I got mine locally under 10 bucks a foot. Big box stores won’t have it.
Thanks everyone, I went with 1.000 OD regular steel DOM, .065 wall, was not very expensive. Easy enough to try something else if this is not satisfactory. Just about finished printing my parts and have placed order for my build kit. Looking forward to it.
