Be nice if the calculator would prevent you from putting in a Z height of less than 81mm…
Ask me how I know!
Ask me how I know!
Doesn’t it turn red when you go lower? 81mm is the size of the feet.
It does not - when I actually read the instructions (after receiving my custom cut stainless steel tube!) it does indeed state that 81mm is the minimum but the calculator is quite happy to let you enter two inches… Ah well
Hmmmm, that would be cool. I am not sure if I know how to do that, but it will be fun to check. Sorry for any wasted cuts that caused you.
No problem, I should have actually read the instructions… You could have the onchange event reset it back to the minimum if it’s less than 81mm.
In other news all parts are printed and construction is progressing nicely Appreciate all the work that’s gone into it.
