I am runing my MPCNC with Arduino mega + Ramps 1.4 + LCD + Marlin 2.0 Bugfix (downloaded from github - MPCNC_Ramps_T8_16T_LCD_32step_DualEndstop ). I milled few parts out of wood with this machine and i am very happy with results. But some parts i cant mill or carve properly. I am using Estlcam for generating G-code (enabled G2 and G3). The simulation in Estlcam is showing proper path, but when i start it on MPCNC via SD card, the path is diferent. It moves in strange ways with some fast movements. (The Zero origin is set in the middle of carved parts, so there are also negative values in the Gcode). I tried the same G-code with diferent firmwire (link from youtube - https://www.youtube.com/watch?v=jlOyqca9AqM) and it works properly. But both firmwire are based on Marlin.
What could be the problem for this? In attachment is example of G-code
How are your steppers wired? Are they in series? You might be able to just use the version that doesn’t say “dual_endstop”.
The dual endstop has soft stops enabled in X and Y. They make sure that you don’t clobber your home switches. So it won’t let you move negative. If you don’t need dual endstop firmware, that’s an easy fix.
You can also disable soft stops with a gcode command:
How stupid i am Thank you Jeffeb … the problem was in combination of dual en stop firmwire + G-code with origin (zero) in the midle of model. It generates G-code with negative values but the firmwire doesnt permit it to go below zero. I changed firmwire on my arduino and now it works fine
