Hello all, I am extremely new to CNC and have been gathering parts for the Primo. I have reached the point where I need to get some endmills. My goal is to mill out some 1/4" ABS plastic sheets to create a faceplate to use on a box I am making. I will be using the Makita RT0701C on my build.
The faceplate will be about 6" x 9" and has some 3.5mm round holes for screws along with some other larger round holes for buttons, etc that will be all the way through the material. There are a few other square “holes” that will not be all the way through, these small square cuts are about 10mm x 4.5mm and would be about 4mm deep into the 1/4" material. They will be used for seating other components into the bottom side of the faceplate. Based off what I have learned, I know you cannot really mill a square hole (and that is not a problem) but I am trying to figure out what endmill I should be looking at getting.
My questions are:
What endmill or bits would you recommend?
Can I do the whole thing with one mill/bit? (I would rather not change bits unless necessary)
Does 1/4" or 1/8" shank matter? I know the Makita comes with a 1/4" collet
Thanks for any help you can give. I can provide more info if necessary, just let me know!
