After seeing how long it’s taking LR3 components to get anywhere, i thought I’d get a shopping list together now instead of waiting to finish the draft table (got some MDF for that guy today).
Pretty sure this one needs to be direct drive for squishy plastic, but I haven’t chosen a hotend or extruder yet. I’ve never been up on what’s what in this area, either, so I’m not sure which way to go. I know it was developed with the Hemera in mind, and the H2 looks similar and very light. Something else? I’d like to reserve the option for high-temp plastics as well, so I’m saving the dual-extruding PLA for the next build after. edit: just saw the orbiter 2.0, looks like fun.
Also, Google is letting me down. I was searching up mgn12h rails on amazon, and I came across a listing for mgn12h blocks on an LML rail. I found a reference to lockable bearing blocks, but these blocks aren’t those. The rail doesn’t look any different to me. It’s it just the naming convention of the rail vs the block?
https://www.amazon.com/dp/B08PKY5RHZ/ref=cm_sw_r_apan_i_X13BBRBKZX5M6MG13FZR?_encoding=UTF8&psc=1
Dug out a board I bought, and it turns out to only have 5 drivers, so I’ll need to get a new one. Any reason not to get the skr pro that Ryan used? I also have 5 TMC2208s that I bought with it, so maybe just pick up one extra and use them?
Finally, I’ve got a couple of the full graphic lcd screens kicking around. What will I miss out on using one of those instead of the TFT?
TIA
