Repetier firmware instead of marlin
I dont know if someone have tried allready to use the repetier firmware, but i really would like to use it.i have it running on my delta printer and especially the eprom usage directly from repetier host and server is super usefull.
As far as i saw marlin has just some minor tweaks from alted … So it should be possible. Any suggestions or something i should be aware? My electronics are just on the way so i can not start testing jet…by the time i can i will upload my config…
I listed everything but the pin change for the lcd. should be easy.
so as i expected…
i am waiting to get my electronics… so after i have everything together i will start with that…
cheers
