I built the MPCNC Primo and learning daily. I have an issue and I can’t figure it out.
At certain times, when a program ends the gantry moves back to the origin as I have selected, then the Z-axis goes negative and tries to drive itself into the spoilboard.
It also does this sometimes when I hit “kill print.”
I’m not Repeater-Host user, but I’ve seen this issue come across the forum before. Most likely you need to change your Printer settings. In Config/Printer Settings/Printer do the following:
That says move the router to Z=2mm, then to 0,0. So if your router is at z=30 it (CAN) will move down 28mm then slide across your work piece.
G91
G01 Z2 F480
G00 X0 Y0 F2100
Is a better option. G91 is relative so move Z 2mm up from where it currently is.
Get rid f the M05 if you are not using it.
Yup and Roberts suggestion is valid. That powers down the steppers and The Z can drop from gravity
