I’ve been a maker before being a maker was even a thing. I hate spending money and I wanted to use some router bits to do some different finish work on some project.
Still trying to figure it out after I built the jig. I figure I cant take out the full cut in one pass.
Interesting idea, you just saving space, I take it? I made a cheap router table a while back. two pieces of 3/4mdf glued together, 3d printed a plate to hold the router, then recessed the plate into the mdf (used the router to cut it). Then I took two pieces of aluminum extrusion and use those for rails the fence rides on, if that makes sense. That thing sees as much work as my miter saw, honestly.
