Hey folx,
Just curious, are there any alternatives to Sandify? Is there a way to convert Sisyphus files into gcode for a corexy build?
Thanks,
Jessica
Sandify is the only tool I’ve heard of to convert thr files to corexy gcode files.
Is there a reason you’re looking for an alternative?
Oh Jeeze! I didn’t realize that Sandify also did conversions! I’ll need to look into that! Thanks for the tip!
Ah. That makes more sense. You can choose import and it will import thr or gcode files. Then you can zoom, change the aspect ratio, or add stuff and save it to gcode or svg. The about tab shows some places with thr files published. There is also a tool called “sisyphus for the rest of us” that has some neat pattern generation.
