I have a scale problem when i use the demo crown in Eslcam and then load the gcode in Repetier-Host the crown is soo small
What is the problem after scaling it in Eslcam
These things should all be included in your post. It makes it much faster to diagnose problems.
Did you buy everything from here?
a)If you didn’t or changed some things please don’t leave out any details.
b)What firmware? -
Are you using end stops?
a)If so please disconnect them. -
Are you using all my recommended parts?
a) If not please list what parts you used. -
Include a picture so obvious errors might be spotted.
What is really small in actual measurements? What size should it be?
