Hi, I’ve come back to finishing my LR2 now that the weather is warmer. I want to have it wired for dual end stops, right now it’s not wired at all. I’m using the default firmware from the store, I haven’t modified anything. Both EXP1 and EXP2 are connected properly as shown here lcd-touch-Labels-scaled-1.jpg (2560×2037) (v1engineering.com). The serial port is connected and oriented properly as shown in that picture as well (single pin closest to the ribbon connectors, +5v furthest from that pin). UART is set to 250000. I’m powering the system from the power brick, not the USB port. I’ve gone through the other posts here about the issue with no luck.
Also, when connecting to USB, Windows reports ‘Device Descriptor Request Failed’.
