Does the pre-flash firmware include the code for the endstops or will i need to reflash? I know the LR3 kit doesn’t include the endstop hardware, but considering all documentation shows endstops and recommends for best accuracy, wanted to know if the pre-flashed unit does or doesn’t include endstop code
You can see which firmware it is. It should be 513S or 513DL or maybe 513D. S is for serial, D is dual x and Y. DL is dual Y and dual Z. If it doesn’t show you on the screen, you can send M115 to get the version.
@Ryan , have you been flashing skrs with the dual lr firmware?
