I also have One of these adapters which allows wifi connectivity with an SKR Pro. These were made in order to be able to run RepRap Firmware on an SKR board. I plan on experimenting with this for my second Repeat build. I have an SD card built to do it, but it also appears that the adapter can be used with Marlin firmware, possibly with the same interface as the Duet Web control, This would allow access to the internal SD card over wifi, and starting jobs from from a web browser, like a phone or tablet.
Personally, the idea of running RepRap Firmware is appealing, as this will allow me to run a Repeat printer without needing to buy a more expensive Duet 3 6HC, or find one of the expansion boards for the Duet 2, which seem to be no longer in production. (At least the local authorized reseller hasn’t had any in a very long time.)
I really like RepRap Firmware, though I guess it might not be everyone’s cup of tea, so the possibility of using it on the SKR Pro is appealing to me (Enough to buy the wifi adapter, at least.) and the Duet Web control is a good interface for it.
I was a little disappointed in the ESP01S when it forced me to use 8.3 filenaming, as I thought that otherwise, it was adequate. The developer says that it’s a limitation of Marlin, but of course we use long filenames in Marlin all the time, now, so it shouldn’t be a Marlin limitation anymore, just the ESP01S firmware still limits to 8.3 filenaming.
