When engraving is the x movement supposed to be so slow? A simple name engrave says it will take 7 hours for a a 6 letter name.
How can I speed this up?
What speed and depth of cut are you using?
Is it possible you have the gcode speeds set to inches or mm/s instead of mm/min?
Typically, when we see this problem, the issue is Estlcam. Under Basic Settings, you should see:
As Jeff indicated, if “Feed units CNC programs” is “Millimeter per second,” then your cutting will run at 1/60th speed.
