I’ve had my MPCNC running for a week or so and I’m very happy. I’m using a cheap Harbor Freight trim router, which works fine, but it’s loud. I’m no stranger to routers, so I’m kinda used to it, but for longer jobs, it’s too much.
If I replace this with a spindle, I know it will be quieter, but will it be $100 worth quieter? The highest noise comes from the cutting, which I don’t think would be that much quieter.
Unless you get a good spindle, it’s not worth the loss in height. Most DC spindles have the collet adapter bolted to a regular DC motor. It adds quite a bit of length.
I have been seeing where people hook the shop vac up to a variable speed switch and then turn it down to as low as possible while still being able to suck. That seems to help decently.
Some vacs use a fan on the spindle to cool so be careful they can get hot I got a dust collector from harbor freight much quieter than my shop vac and I dont have to empty it often
