Right now I have one of those cheap chinesium 500W spindles that can be had for 60-70$, basically just a DC motor with an ER11 collet stuck on it. The biggest problems with it are that the collet is about 2" away from the body of the motor, add to that the length of the bit and it chatters like hell even under relatively small loads, and its low speed. What I like about it is the low noise and weight compared to routers and the price.
I’m looking for the following:
Price between 150-250$
Around 500W, aircooled
ER11 collet
<1kg
20000-25000RPM
not too loud
Does something like that exist?
I found this one from stepcraft, but 530€ is over my budget.
im a bit confused why wouldnt you use the de walt or another router thats fits the plate along with a 6mm to 3mm reducer chuck for er11 bits, the small hand routers are not too heavy and and katsu or zen (makita clones) are cheap
Routers are really only much louder when you are not actually cutting. When you are cutting the noise is very similar between the two types. Typically the dust collection vacuum and the cutting bit are the noise generators.
I have the AMB FME-P 1050. It’s really nice and can handle whatever you throw at it. The ER16 collet is a big plus over the FME-Q for me.
Regarding the sound levels I tend to agree with what others have said. Vacuuming + cutting in even light materials will cause way more sound than the actual router/spindle. I also live in an apartment, and without an enclosure it is not really possible to use it, unless you have very nice neighbors.
As far as I know their collet system has a higher run out than the standard ER16. Also, with a standardized system you can buy the spring collet from all over, while I guess you will have to buy their own system from a them?
Owning a set of ER16 spring collets can be nice if you are into machining and need them for other applications.
