Current Setup:(not bought from shop)
Steppers: https://www.amazon.com/gp/product/B00QEXSCE8/ref=od_aui_detailpages00?ie=UTF8&psc=1
Ramps 1.4 w/ the MPCNC T8 firmware
DRV8825
I am running one motor off of each lead and have the voltage set at .7 ( 2 * .5 * .7) to just test. If I set it any higher than there is a very annoying high pitch sound that is just too much to handle.
My main problem is that whenever I am in repetier host I tell it to jog 50mm. Whenever I do this, it just jerks a bit then goes back to where it was. After this I toggled with the accelerations a bit and changed it from 400 to 1. 400 does not work, 1 does work but is still a bit weird.
So my question is, what are the best acceleration/jerk/max accel settings that I must use to have smooth motion because at the current moment it is just jerking with 400mm/s^2.
