Hi I have a problem.
I have set up a test for controlling the steppers from the LCD and from Repiter-host an I can control
stepper Z,X1 and Y1 but not X2 and Y2, they are dead.
anyone who has seen this before?
I have a Rambo 1.4 from V1 as all other elecrtic parts
gto3000
(Chris)
July 5, 2019, 1:40am
2
did you upload the dual endstops firmware, if not it will assume your using motors in series, 2 motors on x and y.
Thanks for you reply
I thought the dual endstop firmware was installed on the Rambo 1.4
I will try that.
Thanks
gordon
(Gordon)
July 7, 2019, 9:40am
4
I ordered the Archim2 kit with dual end stops
The order said If you bought a bundle or electronics board from this site, this is already done.
Using Repetier-Host to operate the unit
I Connected a RepRapDiscount Smart Controller to EXP1 and Exp2
I connected the end stops to their proper place
I connected all the Steppers to their proper place
I Powered up the Archim2 board
The LCD display is blank, like there is no power to the display.
The Repetier-Host only operates the X1, Y1, and Z the X2 Y2 will not operate
Removing the timing belts, I checked the X2 Y2 and there is no power to the steppers
I then reconfigured the steppers in parallel X1,X2 Y1,Y2
Then using the Repetier-Host the MPCNC Archim2 board operated just fine
My question is, could this Archim2 board not been pre-loaded with the dual end stop, how do I check this.
Why is there no display do I need to enable this in the Configuration.h
gordon
(Gordon)
July 7, 2019, 10:32am
5
Am I using the correct Marlin for my Archim2 board which one should I use?
MARLIN-DUAL-END-STOPS or
Marlin-MPCNC_Archim2_T8_16T_LCD_16step
Gordon you should start a new thread of you own to keep things clear. ARCHIM boards are not flashed, you need to flash it. I have direct links on the firmware page for the ARCHIM boards.
