I hooked up all my steppers and tried to check motion but none of them worked properly. They would hum/vibrate, but wouldn’t move. The belts aren’t too tight as I can move the axis manually. Attached is a video showing what they are doing and a picture of the x axis plugged into the ramps board. In this video the only stepper hooked up is the one in the video. I disconnected all the others to try to isolate the problem. Any help is appreciated.
Do you have one to try that you have not rewired?
What are you using for electronics, drivers, software, voltages, ect.
