Swapping X and Y Axis on a lowrider
Thanks
Sorry to revive an old topic, but I needed to revisit it in preparation for installing Jackpot board in place of SKR board, and still maintain my swapped X & Y axes. To help with that, I needed to refresh my mind on what changes had already been made in my wiring. I made the following graphic to better document those changes:
For sake of others who may wish to do the same with a Jackpot board, I aim to make a similar documentation for the Jackpot, which I will post over here:
It was requested that I share my config.yaml file that accomplishes swapping X and Y axes with the Jackpot board. Here you go! The attached zip file contains two config.yaml files, both with swapped XY, and one is BEFORE adding the Fluid Dial pendant, and the other is AFTER adding the pendant. Remember that whichever one you choose needs to be renamed to just “config.yaml”.
config.yaml (swapped XY, both BEFORE & AFTER adding pendant).zip (4.4 KB)
