Thanks Barry. I printed another, my slicer settings still seem off, ugly surface finish on my prints. The case seems good to go after I move that little center button hole over a few mm.
This will be a bit more work for the edit, but it’s a pretty simple thing, since I just needed to put a hole in it. It’s a 3.5mm by 14.5mm slot that centers 10mm “down” from the SD card. I think it’s 1.5mm from the edge of the card itself, I went even (maybe .5mm back) from the edge of the SD card hole on the one I did.
If you want to do a quick sketch of that, I can make one, or I can just upload the step files to the prusa printers page and you can do another custom one.
I don’t think I have any more of the wifi’s here, at least I can’t find the one I had on my desk. It has to be here somewhere, though.
The PCB just sticks straight to the side from the 8 pin wifi header on the board, so it’s not difficult to model from the TFT board. That was where I took the measurements for where the slot centered in the first place.
This is an SVG from my previous edit, and is the one I’m using on the LowRider.
