I’ve been working on a project with text in a speech bubble. The first time I cut it I didn’t notice that the bit had cut off some of the letters as there wasn’t enough clearance between them for the bit to pass through.
To fix that issue, I cut the original piece’s letters down to 2mm, so I had a relief to line new letters I planned on glueing down. I then rearranged the letters with lots of spacing, planning on cutting them out individually with holding tabs. But I really don’t like this approach as it would be a ton of extra work.
Finally, using a combination of Illustrator, Fusion 360 and Estlcam I got the letters spaces just wide enough that the bit passes through without losing any detail in the letters. I think I’d be faster the next time, but it seems there should be a better way. Are there any tools out there for arranging lettering or any other “island” type design so the clearance is the exact width of the cutting bit?
Long post, thanks for taking the time to read.
