A few more to do but this one turned out well for the wrenches and extensions. Cutting in 3/4" spf plywood, 6mm doc 8mm/s feed, 1/4" single flute bit, with a full depth finishing pass at 10mm/s
I considered cutting boards but I’d be curious to see how foam does, maybe this is a good way to go backwards in the milling basics and really plow through some foam for the socket tray that was proposing a nearly 4hr cut time…
Ridgid foam may be very well suited for this actually
I’ve thought about using the hard foam board from lowe’s or Home Depot. I know it mills well, but I’m not sure how well it’d hold up over time in a toolbox.
I haven’t tried the hard foam floormats from harbor freight, but that sounds interesting.
And are you using your phone to take a picture of a screenshot?
Here’s the second tray. It turned out great, I tried a couple of different pocket options. Linear cut nearly 2hrs from the job vs parallel so linear it was. Same setup as before, 12mm doc, just under 2hrs cutting time.
