Hi I just finished my build and am using Vcarve, what toolpath format should I be saving files as for Repetier to use on my MPCNC?
Thanks!
.gcode is ideal.
I have not used Vcarve but Most CAM products require a post processor, not just a file type. Maybe someone that has used it will chime in. I know it has been talked about on these forums before.
cheers, it has whole heap of post processing options, just trying to find the right one.
As you can see from the pic, the list is endless
Is there a marlin on the list or reprap?
Close, https://www.v1engineering.com/forum/topic/aspire-post-processor/
Unfortunately not.
YAY!
That PP in the link you posted works!
Thanks a lot!
Im cutting perfect circles!
