I have been cutting for about a week now and have decided it’s time I can graduate to endstops :>
Making a touchplate seems very handy since I can put it onto the material and get homed the right distance from it.
I was looking for touchplate designs on thingiverse before making my own. I saw a lot that say they find corners. How does it do that? I thought touchplate was just for z axis?
Have a look at the g38. It has modifiers (38.1,38.2…) that can indicate probe toward, probe away, with or without alarm on failure.
One parameter it takes is the axis to probe. I had it working nicely on my lowrider, but using the default pin as the probe in marlin was a hard fail. I had to explicitly name the pin (even though it was the default) and then it worked great. Only gotcha i can think of.
Marlin has had a lot of development since then, but I don’t know if that was addressed and I’ve been using grbl on my cncs after that.
Sometimes I get carried away with the detail of a question and forget to look for the bigger point. So, disclaimer:
I did it, it was fun, and I learned a lot about marlin and gcode along the way. I probed xy MAYBE a few times, and those were just checking that it worked. I have never, even once, had occasion to probe xy for a job. Turns out most of us like to place stock at a known location on the spoilboard.
Smart money says its a fun project, but won’t be useful.
That said, this IS a hobby for most of us, so if you want a little more info, these might be helpful.
The corner finders never made sense to me, because they don’t detect the angle of the workpiece anyway. I usually just manually set up the jobs anyway.
Even if you want to make it yourself, you should at least look at what he’s made. The clip grabs the magnet, and then magnets to the bit. The touch plate is precisely 0.5mm thick.
Not by default, but it is possible. Estlcam has this build in. I analyzed if it would be doable with Marlin, and it actually is. It is a matter of doing some touch points and make a custom Gcode command. Was going to experiment with it myself but the life happened:D
The aluminum tape is what i use i cut a straight edge on the left side of my spoilboard for the X zero and use it to set x zero and Y zero the probe for Z zero on cut surface. I have to have a uncut Z surface to do a tool change so i plan that ahead but it works great and 0.01 mm for the tape if i remembered correct got the by measure the tape the then subtracting the backing thickness.
