Hi there just got the last parts for the lowrider2, and i was wondering if it was possible to use the trend t4 router for it or if anyone has used it.
Not sure if that plunge base will fit.
Ok thank you, what about DWE6005 will that fit?
Yea, that looks like it would fit. Don’t drill the stock mounting holes in the plate dxf though. Use the router’s plate to mark where the correct holes should go.
Grate thank you.
